A/C fan blows while car is off!
  • motorsports_3
    • Mar 2007
    • 1058
    My A/C system operates if the car is on or off. I could go outside right now and turn the fan switch and/or snowflake button and the fan would work and the button would light up, without the key in the ignition. I dont want to forget one day and drain the battery, does anyone have an idea what may be causing this?
    I have an 88 325 with an M50TU swap, JIC.
  • bmwguy325is
    • May 2011
    • 1263
    Im guess the compressor clutch locked up.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • pandaboo911
      • 2070
      Someone prolly spliced some wires wrong on c101?
      • motorsports_3
        • Mar 2007
        • 1058
        I did the wiring. I thought that as well, but it didnt do it directly after the swap. It happened more recently.
        If the compressor clutch locked up, why would that power the fan as well?
        • u3b3rg33k
          • Jan 2010
          • 2452
          what?
          Ich gehöre nicht zur Baader-Meinhof Gruppe
          Originally posted by Top Gear
          Just imagine waking up and remembering you're Mexican.
          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          • motorsports_3
            • Mar 2007
            • 1058
            Bump, any ideas, maybe a stuck relay?
            I looked at the wiring diagrams and none have mention of the A/C system?
            • motorsports_3
              • Mar 2007
              • 1058
              No one?
              • u3b3rg33k
                • Jan 2010
                • 2452
                I'd definitely consider a stuck relay. Pull out your Bentley and see "what's up with that".
                • motorsports_3
                  • Mar 2007
                  • 1058
                  It was a stuck relay. Thank for the help guys
