My car out of now where decided to bog die and die. Tried starting it back up and ran like crap and idled around 500-1000 rpm then slowly dropped and died. Could keep it running a little but if I gave it gas it might rev for a second then would bog and die and would not start.
Let it sit for 5-10 minutes and could get it started but same thing super rough idle would drop then die. maybe longest I had it running was 2 minutes.
I am thinking it is the fuel pump but going to try and do the jumper wire for the relay like the bentley says.
Any other ideas? It is a 87 325e and has the 2 fuel pumps.
Has new timing belt, cap, rotor, plugs, fuel filter done 2 months ago
