Hey R3v,
Ive been trying to diagnose my idle issues since i bought the car 2 months ago. ive thrown a ton of replacement parts at it. I thought it was a vacuum leak, and have tried using carb cleaner to try and find the leaks, but that didnt work at all. heres a list of parts ive replaced...
- cap and rotor
- ignition coil
- spark plug wires
- spark plugs
- intake boot
- fuel pressure regulator
- fuel filter
my idle doesnt jump up and down erratically. its kind of searches between 700 rpm to 800 rpm. My dad says it sounds like its running on 5 cylinders, or as if it's cammed (super lumpy idle)...
Also, when i got the car tested for emissions, it failed due to high NOx numbers...tester said it was a lean Mis-fire??
can this idle issue be due to the coolant temp sensor, or a faulty fuel pump?
I stomp tested the bitch and i get no fault codes...
HELP!
- cap and rotor
- ignition coil
- spark plug wires
- spark plugs
- intake boot
- fuel filter
HELP!
