power window problem
  • Racer@heart
    • Sep 2005
    • 87
    ok its 90 and my windows decided to stop working... fun huh... i am getting no power to my regulator motors and i cant seem to find a fuse or relay for this problem... any ideas?
    '84 318i
    '87 325is
    '86 325is
    '89 M3
  • rs4pro3
    • 5808
    Check the circuit breaker, it's located either in the dash above the radio or in the center consule by the window switches. Check to make sure it's pressed in.
    85 325e 2.7 ITB'd stroker
    • bimmer8604
      • 3017
      do you have power going to the switch? I've heard its common for the wires in the doors to get old and brittle and break due to the opening/closing of the door.
      Kyle
      1988 M3, 97 840, 99 XJ
      DILLIGAF
      • Racer@heart
        • Sep 2005
        • 87
        is the circut breaker a silver box by the hazards...?
        '84 318i
        '87 325is
        '86 325is
        '89 M3
        • arsevader
          • May 2005
          • 1025
          It's usually black but yes on some cars it's next to the hazard switch. It pops out when the breaker trips. Push it back in till it clicks.
          James
            • 37832
            It's not behind the dash, it's a button on the dash [but most likely in your car it's in the center console]
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Racer@heart
              • Sep 2005
              • 87
              i found it... it didnt help so i put a fused link inbetween the wires and now my windows work again.... is a fused link a bad idea?
              '84 318i
              '87 325is
              '86 325is
              '89 M3
              • bimmer8604
                • 3017
                Well, it tripped for a reason, I would say that as a temporary fix to just roll your windows down and leave them down is okay. But I wouldnt run around like that for long...
                kyle
                DILLIGAF
                  • 37832
                  It's always possible the button/breaker went bad
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • bimmer8604
                    • 3017
                    what exactly are you jumping here? If you are just jumping the breaker thing inside the car, then yea thats fine, but when you start jumping fuses/relays then you have a problem.
                    Kyle
                    DILLIGAF
                    • Racer@heart
                      • Sep 2005
                      • 87
                      no i am just jumping the breaker with a 30amp fusable link until i can afford to buy a new breaker...
                      '84 318i
                      '87 325is
                      '86 325is
                      '89 M3
