Any idea what this is and where it goes?
  • Andy.B
    • Sep 2011
    • 1650
    87 325e
    Sensor(?) was hanging down under right front corner, behind the valance. Looks to be connected to a plug on the factory harness, but it could have been wired in by a po for all I know.
    This is where it was plugged in, and you can see the wires join the harness running across the front of the car:
    The sensor has the text:
    20PS 1000-001
    P6T
    Texas Instruments
    and looks like this:
    I dug through realoem for quite some time trying to find it, but didn't have any luck.
    Any ideas?
    PS, ignore the terrible hacked wiring. I am in the process of undoing all of the shoddy repairs of previous po's, including lots of wiring repairs. I have a page long list of little terminals, plugs, and other bits coming from the dealer. I just can't figure out this sensor.
  • Andy.B
    • Sep 2011
    • 1650
    Should I assume from the lack of response that it isn't a part other people have and is likely aftermarket?
    • CW325
      • Jul 2011
      • 1434
      temp sensor for obc?
      • spdracrm3
        • Sep 2009
        • 959
        part of a broken A/C pressure sensor
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • Andy.B
          • Sep 2011
          • 1650
          AC sensor sounds reasonable. The car's ac is completely fubar'd, so I will check to confirm if that is in fact what it is for, and then figure out a way to cap off and preserve that connector so I can repair it someday.
          • Ceeker
            • Sep 2009
            • 2821
            a/c sensor for the receiver dryer.
            • kojack
              • Aug 2011
              • 44
              Do yourself a favor and go get a different dryer from a scrapyard, its gonna be a bitch to get the broken end of that sensor out of yours.
              • Huff
                • 2488
                That's your high pressure switch for the AC system. It usually plugs into the dryer.
                That's the original/ older switch. They are no longer sold
