Alternator??
  • Eydreeyun
    • 584
    Alternator??
    So 2days ago car died, figured out it was the battery so I bought a new battery. fast forward today my lights were dim, cluster lights flickers and radio works intermittently. Could it be just the ground?
  • george graves
    • 20003
    What's the voltage when the car is running?
    Originally posted by Matt-B
    • EuroSportChicago
      • 3
      Take a volt-meter and put the positive to your positive terminal and the negative to your negative terminal. If it is NOT reading 13 then you found your problem. Check the wiring as well to see if it could be one of the wires that is shorted out.
