someone pleae help ABS CC systems
  • bastianshaw
    • Jan 2007
    • 2210
    MY ABS light is on I tried a new relay and and its STILL on, this was after a jump start so I was pretty sure it was the relay.
    Cruise control not working I thought it was the clutch switched but changed it and still nothing
    Are there any fuses or relays that these systems share?
    ANY ideas?
    IM starting to get really frustrated
  • vpilarrt
    • Jun 2006
    • 2096
    They share the brake light switch and its fuse (#6).
    • bastianshaw
      • Jan 2007
      • 2210
      Yeah just looked it up in the bently and noticed there is a "built in safety circuit" anyone know how this is reset if possible?
      • bastianshaw
        • Jan 2007
        • 2210
        fuse and relay both good...if I hsve to replace the harness im gonna be PISSED
        • vpilarrt
          • Jun 2006
          • 2096
          Test your brake switch?
          • accident
            • 7303
            I've never seen an E30 with working cruise control.
            Moral of this story?
            • bastianshaw
              • Jan 2007
              • 2210
              Must be the wires
              • bmwstudent
                • Sep 2011
                • 1364
                did you eve think it could be one of the sensors, what does jumpstarting the car have to do with the abs relay?
                • bastianshaw
                  • Jan 2007
                  • 2210
                  on this case the abs light was NOT ON BEFORE THE JUMPSTART
                  • accident
                    • 7303
                    Missed that it failed after you jumped it. The ABS relay likes to fail when the car is jump started. You need a new one. I've seen it happen several times, it's a pretty common failure.
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      its good i checked it.
