Battery Draining Fuse 21 HELP
  • bimmer206
    • 237
    I'm stumped. Alternator and voltage regulator tested and are fine, new battery last week, as well. Battery started dying overnight and at work. Through test light and pulling fuses, I have narrowed it down to fuse #21, which according to my Bentley Manual powers:
    - Auto-charging flashlight
    - Ignition key warning/seatbelt warning
    - Interior lights
    - Radio/antenna
    - Trunk light
    - Multifunction clock
    - Service interval indicator
    Individually, I disconnected the interior lights (glove box and courtesy lights), radio, trunk light, OBC......test light stayed on.
    My SI lights stay on in the cluster when the car is OFF. From this thread below where a guy had the same problem as me (which i copied) it seems that the SI board may be sucking the power because the batteries went bad and the car is trying to charge them?
    Reference: http://www.m42club.com/forums/showthread.php?t=12048
    What is killing my battery????
    Edit: My power radio is removed from the car.
  • Chuck C
    • 104
    Your test light is indicating voltage, and what you need to measure is amperage. Get an amp clamp and a good digital volt-ohmeter to check exactly how many milliamps you're drawing, then disconnect one component at a time. From experience, I would guess a light is staying on. I don't think the SI board is the problem, as fuse 21 just supplies memory power to the board. Happy hunting.
    • bimmer206
      • 237
      The SI board is on when the car is not running and off when the car is 0.o
      • 36brua
        • 689
        power antenna ? try disconnecting in trunk even though you have pulled the radio
        My CA legal M60 swap
        The happening in our garage
        • Chuck C
          • 104
          Antenna is not on fuse 21.
          • bimmer206
            • 237
            Chuck you seem to know a lot about this problem and your in Seattle, want to give me a hand?
            • DÌEGØ
              • 690
              yeah what chuck said. you need to measure amperage not voltage. my SI service LEDs are ALWAYS they'll draw 12v but not enough amp to drain the battery.....
              Driving:1990 325iS, 2007 335i :devil:
              past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
              • evilnickwong
                • Aug 2007
                • 302
                I have the same problem. I measured current draw on my car, which was gone when I disconnected my cluster.
                My SI lights don't stay on (I looked at it in pitch dark and don't see anything), but I've also read that bad batteries can make it constantly try to charge, hence the draw. I have not tried replacing the batteries yet. Right now, I just disconnect the battery whenever I'm not using my car for awhile.
                • DÌEGØ
                  • 690
                  make sure the battery is clean too. you'd be surprised how much current dirt and crap on a battery will conduct
                  • bimmer206
                    • 237
                    Batteries connection is rock solid, i still have this problem but I've been driving around with fuse 21 pulled. I pulled the cluster to see if this was the SI lights but no luck. Ill measure voltage soon..
