Right Way To Remove The Wiring Harness Through The Firewall
  • ChocolateKrackers
    • Mar 2004
    • 233
    The last thing I'd do is cut and there is no way in hell I'll end up doing that. So before I even start pulling on it, both ends are 100% disconected from everything (under the dash above the glove box and in the engine compartment), any tips or trial and error recomendations? Thanks everyone
    "My backpack's got jets..."
    ~MC Chris is my co-pilot~
    • 37829
    Just disconnect it from the ECU, pop out the weather seal or whatever you want to call it that goes around it in the firewall and feed the end out from the inside. It's very easy.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • ChocolateKrackers
      • Mar 2004
      • 233
      Thank you, I was unsure if the seal/grommet was removable or you had to pull the harness through it. I was pretty sure if you did the grommet would be destroyed.
