Brake lights don't work, checked pedal switch.
  • AwakenNoMore
    • Dec 2010
    • 1291
    What do I do now? I'm not great with wiring. The running lights illuminate when i pull the headlight switch, but when i push the brake pedal I'm not getting anything. Where do i go from here, haynes manual useless.
    1991 325i - "Scambles" The Daily Driven lightly modded.
    1988 Mazda RX-7 TII "Mako" The Free Dorito
    bacon by Jared Laabs, on Flickr
  • AwakenNoMore
    • Dec 2010
    • 1291
    Also just checked cruise control doesn't work as well. When i checked the switch the car was off does that matter?
    • AwakenNoMore
      • Dec 2010
      • 1291
      Any help would be appreciated, sarched and all the results dealt with removingor modifying the 3rd brake light or a different issue.
      • gp.plus
        • 416
        • AwakenNoMore
          • Dec 2010
          • 1291
          um, can't read that.
          • Chaz
            • Jul 2011
            • 432
            Better?
            And also for your brakes it could be your brake switch sensor that has gone bad and doesn't read when you push the pedal. But look for blown fuses and see if that helps.
            • gp.plus
              • 416
              Sorry bout the pic, I could read it fine on my phone, but yea, brake lights and cruise are the same fuse, most likely your problem.
              • AwakenNoMore
                • Dec 2010
                • 1291
                fuse was the first thing i checked, hmm maybe its the ground? i've heard that its in the trunk somewhere.
