Help identify 2 connectors under dash...
  • bacain32
    • 168
    I was changing out my brake booster, and these 2 connectors fell out from the wiring. I can't for the life of me locate where they went, nor can I locate them in the Bentley ETM. The car is an '87 325is. I can see the gray/red stripe wire is usually for lighting, and a green/red stripe wire is usually for 12v power, but locating these is tough.
    First is a jumper, green with red stripe, male blade style terminals
    Second is a cut-off-by-previous-owner 2 pin connector, red with green stripe and gray with red stripe, bullet style pins.
    Thanks in advance
    '97 M3 LS3 V8, '90 S54 325i, '90 325i touring, '99 540i touring, '94 325is
  • devon.818
    • Feb 2011
    • 2937
    isnt the bottom one for the door chime?
    • Farwest92
      • Jul 2011
      • 192
      Manual or automatic?
      • bacain32
        • 168
        Manual, sorry for not mentioning.
        Chime looks like it's all wired up, I'll check again.
        I picked this car up with no engine or trans, dash torn apart, I have everything back together working for the most part, can't tell on everything until I get the engine harness back in.
        • bacain32
          • 168
          Thinking the cut wire may possibly be for the original radio?
