hey everyone, I have removed my share of these but installing one is a whole other story.. (Grin) if you don't want to end up doing one, make sure you have the latch always lubed cause if you don't you stress the cable it stretches and eventually the cable snaps or the plastic pull handle snaps. the latch is everything.
to get the cable in you need access to the grommet. Try not to pull this out otherwise it's a real pain getting it back in from the inside of the car.
pull the cable through from inside the car. Remove the hood adjuster from the left fender so you can have access. lube the grommet and cable end and get a long flat head screwdriver to push the latch end of the cable through the grommet. From there it is easy street! Not entirely sure if a new one from bmw carries a new grommet or not. Mine had one but to avoid the hassle I just let the grommet remain on the cable and slipped it through the existing one.
