It is about 5 degrees F here in Chicago. Anyway, my car is sitting out all day at school, and i get home with no running problems. It sits outside for 3 hours at work from 5pm-8pm, and it just turns off. Then, the check engine lights comes on and stays on after I start it again. I'm thinking, ok w/e. Then, I start driving and the engine just looses power. I try going above 1500 rpm and the engine nearly stalls every time. I let it warm up to ideal temperature (middle on the temp gauge), and the light goes off and I drive away fine. I'm thinking I was running way too rich, because the cold start valve was dishing out a bit too much fuel. Can anyone tell me if I'm on the right track, and if I need to, or should replace anything?
My car starts to stall in very cold weather
Did you run the Check Engine fault code test? If not, go here and do it, it may tell you something useful: http://www.unofficialbmw.com/repair_faqs/motronic.html
