water leak
  • backwoodsE30
    • 122
    water leak
    where is the water coming from and how do i fix it. the floor is wet on the drivers side down by the dead pedal. any ideas?
    alcoholics do it till you barf
  • trigtm
    • Oct 2009
    • 50
    Sunroof drains, cowl...
    • Ceeker
      • Sep 2009
      • 2821
      Cowl most likely rusted out - typical and often happens when leaves build up and water has no where to go so it sits in the area until it rots through. This is a design flaw from factory as water doesn't drain down into the fender well properly. you may need to remove the fender and fender liner to inspect the damage and repair it. Maybe only the liner. start there.
      • backwoodsE30
        • 122
        yikes time to do some exploring i guess. where do the sun roof drains come out? from the out side there is not a stitch of rust on the entire car.
        • drez14
          • Jun 2011
          • 211
          Is it for sure water and not coolant?
          When that was happening to my car i found the heater valve to be busted and letting coolant leak.
          • ACHTUNG
            • May 2005
            • 2397
            I'm a little confused? Where is the location of the cowl?
            1989 US E30 Cammed S52
            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
            • backwoodsE30
              • 122
              almost positive it is rain water
              • StereoInstaller1
                GAS
                • 22679
                2 words: Elephant Trunk.
                Search and learn.
                Good luck!
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
