Electrical Issue in main power cable of SpecE30- ideas?
    Originally posted by StereoInstaller1 View Post
    Can you post a link to your kill switch? I have never seen a proper battery disconnect that was 6 pole.
    are you looking for a link to where I bought it or an actual picture of it installed?
    I picked up the sparco one from turner. Great product. I installed it in the 3rd hole for the windshield wipers that would be used for right side drivers cars.
      The description is wrong. That is a three pole switch (six connections). The Bimmerworld description of the same switch (called a four pole) is also wrong. One pole is one contact in the switch which means one pair of contacts.
      At the risk of being redundant, that is a bad location for the kill switch (see my earlier post and I have the pictures of the result to prove it).
        Jim, thanks for the input. I do see the reasoning you have behind a better location that you have recommended. A lot of the car will be stripped down to go into paint and I will likely move everything then putting it back on. Thanks again.
