Steering rack
  • Spencer
    • 767
    Steering rack
    Is it true that steering racks were steel up to 87 then aluminum?
    Is one better than the other and if so why?
    Will a rack from an 87 fit my 1991 with ABS and SRS?
    Thanks,
    Spencer
  • mcgrath
    • May 2004
    • 445
    The rack origianlly on my 85 318i and the one in it now from my 84 325e parts car are both alluminum and 100% interchangeable even though They had different part #'s and looked slightly different it bolted right in.
    • Joe318is
      • Sep 2005
      • 6451
      It will work if you convert to front drum brakes.
      Originally posted by vlad
      • mcgrath
        • May 2004
        • 445
        Think you got ahold of some bad crack.
        I just checked the latest ETK says from 86-92 all racks have the same part # so it will work.
        • AdamF 88iS
          • 2051
          Some racks are half steel and half alu, others are all alu.
          The steel ones last a little longer.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
