So I have been having my brake light indicator one up above, whenever I put the key to run (2). The check engine light also comes on the dash, but once I press the brakes, both lights disappear. I have checked the bulbs and they appear fine. As do the fuses. Does it mean that the bulbs are about to burn out or do I have a separate problem on my hands? Thanks
Brake Light On Indicator.
That's how the check panel works. It's normal. And the flashing "check" on the gauge cluster is NOT your check engine light. It's just a check light that let's you know that you should check your check panel.
In other words, its a system and its working correctly.
Taylor -
2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
It's does it because the check panel always checks for equipment functioning properly. It doesn't have signal until you hit the brake switch. Once you've touched the brakes, it checks to see that everything is working as it should, then shuts the light off.
Clear enough?
It's called a CHECK PANEL. It checks everything out before you start driving. If something is not right, the light in the check panel will stay lit. And the flashing CHECK in the dash just tells you to CHECK the CHECK PANEL.
TaylorComment
not to thread jack but i will. on mine, after you hit the brakes the check dash indicator goes off but not the check panal light. but on a warm day it does?????????????????It's does it because the check panel always checks for equipment functioning properly. It doesn't have signal until you hit the brake switch. Once you've touched the brakes, it checks to see that everything is working as it should, then shuts the light off.
Clear enough?
TaylorsigpicComment
yea, I got that from the other thread. ThanksIt's does it because the check panel always checks for equipment functioning properly. It doesn't have signal until you hit the brake switch. Once you've touched the brakes, it checks to see that everything is working as it should, then shuts the light off.
Clear enough?
Taylor2014 Alpine White 335i MSport
(Daily Driver)
KW V2 Coilovers
Clean your check control relay, it is likely corroded/oxidized, clean all the contacts in the plug that goes to your tail light panels, clean the contacts on the bulbs.
Use CRC 23 or other electrical contact cleaner and pipe cleaners to clean with.Comment
