So after I replaced my fuel pump, fuel filter, and did an oil change on my 1991 318is, I was hanging around the engine and listening b/c I thought I heard something weird. There's a slight hissing sound (which I found a BEN article on about the timing chain, tensioner). Can anyone confirm this will fix the sound?
More importantly is the slight hesitation when I push down the accellerator when the car is at idle. It pauses for a second and then accellerates the engine as usual. When the engine is under a load there isn't the same pause, only when the car is accellerated from idle.
There seems to be a lot on the M42, so let's see if anyone can help here.
Thanks all!
-Prince
Thanks all!
-Prince
