I am down 2 fuel injectors right now for my Eta and I need to buy some new injectors, I called Patrick at BMA and I checked a few other places for a pt number and I cross referenced it and they at 26# injectors. Is this right? The pt numb is 0 280 150 126 I was going to get some 19# mustang injectors before I found out that they were 26#'s. What should I do?
Fuel Injector question
Tags: None
You will instantly fry your DME if you run the wrong impedence injectors.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Right part #.Wrong flow rate.Low imp/Rate at 18.2lbs @43.5psi.....you looking for stock used set?Comment
It wont be 26lbs. Even 325i injectors are 14.5# @ 3.0 bar. If you want to upgrade then you need a set of low impedance from say an m30 powered 3.2 liter motor. Someone correct me if I'm wrong, but I believe you can use them from a 533/633/733 motor, and they flow more.Last edited by EtaSport; 09-28-2005, 06:19 PM.Old and improved:
those values are correct
"e" injector 0 280 126 is 18.2lbs@43.5psi = 16.6 lbs@36.25 psi
I was giving him a 43.5psi rating so he can source some.Since most sellers use the 3 bar not 2.5 bar rating as found on etas. or he can use 17lbs @38psi.......its just different rating for the same injector dependant on pressure.Comment
How much should a new set of 6 injectors be?
-PrinceComment
