clicking sound when i try to turn my car over?
  • timninja
    • Feb 2011
    • 302
    I just recently did a head gasket and now when I go to start my car I hear a *click* and its not a dead battery,but I think I located the clicking and its at the Bosch relays that aren't in the main fuse box,and the fuel sensor at the end of the intake manifold.any ideas what's.wrong?I'm somewhat electronic illiterate.
  • mikeedler
    • 6707
    you have a bad ground for your block? check the wires on your starter.
    • AndrewBird
      The Mad Scientist
      • 11897
      $10 says the ground wire from the chassis to the oil pan is disconnected or loose.
      • timninja
        • Feb 2011
        • 302
        Ohh I painted my valve cover and there was a ground from it to my front battery tray,but ill.check thoose after work thanks guys
        • Hey_You
          • Nov 2009
          • 963
          Yes! Make sure that valve cover ground is...well, grounded. Then make sure your battery is fully charged. Then check your starter connections. Then check your starter relay. But seeing how you hear it click, I would imagine that the relay is fine.
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
          • Adrian_Visser
            • Jun 2006
            • 2823
            There should be a large ground wire from the oil pan to the frame rail on the driver's side. Surprisingly though that small ground from the valvecover is enough for the starter's current. Unbeknownst to me I ran like that for almost a year.
            '89 Alpine S52 with goodies
            • 5Toes
              • 9836
              You better hope its not your starter :p
