So after getting my car together I have a VERY high idle. It is constant and roughly about 1800 rpm. I have searched and I think it might be a bad TPS... mine has never had a real "click" (that I can tell anyways). Though the idle is high... the idle is VERY SMOOTH!
When doing the starter I cleaned the icv and the afm. The ICV I noticed has a thing inside that spins open and closed. I spun it open with my finger and cleaned it out good. I sprayed brake cleaner in there and then put it in a rubbing alcohol bath in a sonic cleaner. It hums when the ignition is on.
I replaced ALL of the vacuum hoses (except the intake boot and breather hose) also when I re-assembled the car. The intake boot I didn't see any cracks, but I did not look too hard.
I am going to go check the resistance values of the ICV, TPS, and AFM tomorrow. I will report back. My main question though is, could a bad TPS cause this high of an idle. I did polish the insides of the throttle body, as well as clean it up. The tps may have gotten bumped a few times in the process. Though today with it idling, I pushed the throttle the opposite direction to see if the TPS would switch on (if it was incorrectly set). No luck.
Goign to go try the penny trick, will report back.
