OBC - MPG vs M/G
  • Disco Benny
    • Aug 2011
    • 123
    OBC - MPG vs M/G
    So on the e30 OBC you can toggle between liters per gallon and miles per gallon which are reflected by LPG and MPG.
    What is the M/G number and what does it stand for? The M/G is always consistently higher than the MPG number
  • scottinAZ
    • Dec 2009
    • 1312
    m/g is imperial gallons as used in england
    I saved 15% on my Bimmer parts by switching to ...
    • Disco Benny
      • Aug 2011
      • 123
      Ahhhhhhh, Nice!
      Thanks!
        If you are talking about the difference between what the OBC MPG reading and the econometer readings you need to know that the econometer is driven only by injector on time. The OBC is using distance covered, fuel used, and rate of use (injector on time) and its display is time averaged. So the numbers will be different between the two instruments.
        • Wh33lhop
          • 11705
          No, he is referring to the OBC when you hit "set" while you are in the fuel economy display mode to cycle between units/languages. It will cycle between L/100km, M/G and MPG. M/G indicates imperial miles per gallon, MPG indicates US miles per gallon.
          paint sucks
