Windshield Needs Replacing
  • Disco Benny
    • Aug 2011
    • 123
    Safety inspection coming up and I need a new windshield.
    How much does it cost?
    Is it better to go to Jiffy Lube to get replaced?
    Better to get glass from Dealer then have a shop install?
    Questions...advice, etc...
    I have a huge crack in the windshield, doesn't leak but definitely prevent me from passing the inspection
    I go through a windshield or two each year on the race car. I use Safelight for the glass and installation. The last one I had done cost $240.
    • jrobie79
      • Mar 2006
      • 2526
      I bought one from Giant Glass, just the glass and did it myself in less than a half hour, some people say to buy the BavAuto tool, but that didnt work for shit for me, I just used a plastic one inch tape knife, and a some spray can silicone lube.
      edit: PPG or whatever the new company name is cost me 100 out the door.
      1991 318i ---- 308K - retired
      • ParsedOut
        • Sep 2005
        • 1437
        I have another car with full glass coverage (wife's car), most glass places will rebate you up to $100 when using insurance. So I just had both windshields done at the same time and applied the credit to mine, the total bill came out to $75... Otherwise the cheapest quote I got was $150 installed but that guy seemed a bit shady, most legit quotes were $200-240.
        • long tall eta
          • Jul 2010
          • 1536
          gona do mine in the spring due to the molding being more pliable in warm weather but as i understand it, it's any easy job. the glass just pushes out from the inside after removing the molding. the new glass just gets set in there and replacing the molding will center it up. any body want to chime in if this is correct or not. new glass can be had for 140 or so.
          • sofargone561
            • Jan 2011
            • 250
            i need mine done as well but im not replaing any glass until i can afford to get the car pressifally painted. then i will pull all the windows and panels and what not out and epaint the car then all new glass! =)
            my build thread:
            http://www.r3vlimited.com/board/showthread.php?t=231612
              • 37833
              Around here you can get a brand new one installed out the door for $120.
              Grover Beach, California
              BimmerHeads.com
              • MrSlacker
                • 2494
                I have a brand new windshield gasket that we didn't use when replacing a friend's windshield. Its OEM from the dealer. Let me know if you want it.
                My Seller/Buyer Feedback
                Performance Aftermarket Parts & Accessories
                • LagunaVert
                  • 255
                  I pulled a junkyard special windshield and put it in in the same day. Just pull the lock strip out, and push the old one out from the inside. The hardest part for me was getting the "new" one inside the gasket. Start from a bottom corner and take your time working it into the gasket and you should be fine
                  TWELVE HAMMERS
                  • Disco Benny
                    • Aug 2011
                    • 123
                    so this is nice, just got into an accident this morning...
                    So I guess insurance is gonna just replace windshield along with bumper haha...if they don't total the vehicle that is
                    • LagunaVert
                      • 255
                      If the bumper and windshield need to be replaced then they will probably total it. You will be lucky if you make it out with a clean title.
                      TWELVE HAMMERS
                      • Disco Benny
                        • Aug 2011
                        • 123
                        The car is in pretty solid condition so this is going to be interesting
                        I really would like to be able to drive it again but we'll have to see
                        • Greilly
                          • 38
                          Do you still have then windshield gasket? I ocild use it on my 90 convert. E mail me at 215.493.3791. Thx gene
                          • Vivek
                            attention whore/retard/bitch
                            • 6167
                            How bad was the crash? Bumper and windshield could be like 2k at the insurance body shop, even though you could do it yourself for like 400.
                            1992 Mauritiusblau Vert
                            2011 Alpinweiss 335is coupe
                            2002 540i/6 Black/Black
                            2003 GSX-R 750 (RIP)
                            • bmwstephen
                              • 2463
                              just get a good one for 20 dollars at the junkyard. the beauty of these pull-in windshields is that they are easily servicable
