My current 20+ year old tank has completely rusted through on the fill pipe. It's dumping rust into my fuel and fudging everything up so I'm going to go ahead and replace it. I already have to drop the driveshaft for a guibo/CSB/trans output flange so now is the best time.
I've read up on the little bit of information available in preparation to do this. My main question right now involves the aftermarket tank I will be installing.
This is the tank I will be using:
The tank doesn't seem to be painted or coated in any way. Is there any reason I shouldn't just plug the holes and spray it with a truck liner or some sort of rubberized spray, or even just black paint? If this isn't a terrible idea does anyone have a suggestion on what to use?
The other question I have involves the fuel hoses. I went ahead and ordered the bent hoses for the fuel filter, the return line from the filler to tank (braided looking one), and the filler neck hose all from pelican. Are there any other specialty hoses I'm missing? In addition to this what size fuel line will I need to take care of the rest while I'm at it? I'd like to take care of all the soft lines while I'm doing this job. I would have done the hard lines as well but time and money are constraints right now after everything else and I'm not comfortable bending them myself.
Thanks guys.
Thanks guys.
