quick heat issue
  • Kozworth
    • May 2011
    • 1339
    quick heat issue
    Coolant is bled, new t stat, new wpump.
    Heat only works when its warm out. All hoses are hot but inlet/outlet heater core hoses.
    Coolant is all new.
    There was no debris in the coolant when i drained it. Before I go to town on the core, is there any options if its the valve vs the core?
    • 37833
    Are you sure the heater core hoses aren't backwards?
    Grover Beach, California
    BimmerHeads.com
    • Jafxod
      • May 2011
      • 1301
      Bleed it again with the car jacked up in the front and with the heat on in the car.
      • Kozworth
        • May 2011
        • 1339
        Pretty sure, never touched them. P/o said heat worked but never tried it until after I replaced a wpump.
        I did bleed it for a good half hour jacked up front with the heat on massaging the hoses and bleeder screw open
        • dnguyen1963
          • Nov 2011
          • 2651
          Your heater core is likely plugged. Disconnect the heater hose and use a garden hose to flush the core...see if you can get any water through it.
          • Kozworth
            • May 2011
            • 1339
            is there a way I can block the coolant so I do not have to rebleed the system?
            And if the core was plugged, wouldn't the hoses be hot anyways
            • Kozworth
              • May 2011
              • 1339
              Edit: rechecked heater hoses, they are warm but not boiling hot like upper/lower rad hoses
              • MikeDE
                • 1873
                Check this^....why you ask?? See answer below...
                Originally posted by Poor Adam
                P/o said.....
                That's why...most p/o are a) Dicks and b) rarely give the whole story b/c they wanna sell the car and they're too embarrased.
                -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                • Kozworth
                  • May 2011
                  • 1339
                  Ill check the bentley to make sure, but p/o and I are tight so if there is any issues it would be the p/o before him. Thanks for the tips though
