Winsheild washer lever.
  • e30 gangsta
    • 3877
    So i select a speed and it does it, but suddenly it stops or comes back as it feals like it. If i put a little bit of pressure holding it up it stays on like it should. Anyone know if i can fix anything or should i just replace the whole lever?
  • screamingbmwe30
    • Jan 2005
    • 415
    replace it
    • e30 gangsta
      • 3877
      Any write ups or quick ways to get to the lever?
      • mikeedler
        • 6707
        pull the steering wheel off, and the lower plastic from the steering column. you will then see the 2 screws, and follow the wires down to the plug. unplug, and plug the new one in. 2 easy!
