water pump Question
    water pump Question
    so my water pump started leaking from the shaft. i think. but upon looking at my old one i saw this hole. is it possible that coolant could leak from this? what is its purpose? kinda odd to me.-some pics:
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    That is a weep hole. It is after the seal, but before the bearing and its purpose is keep leaking coolant away from the bearing. Coolant getting into the bearing can rapid failure of the bearing and subsequent damage to the fan, radiator, etc.
      / thread
      Ma che cazzo state dicendo? :|
        so when coolant leaks from the weeping hole its the sign that the water pump is bad. correct? and the hole helps protect the bearing from being completely destroyed.
        thank you. my "new" water pump of 7 months is now leaking from this i believe. gahh
        Got Drop?? ;-)
        But of course
          you got it, if its weeping, its dead
          I saved 15% on my Bimmer parts by switching to ...
