Fuel Leak, Found?
  • Threehz
    • 1480
    Fuel Leak, Found?
    So my car is leaking fuel somewhere, you can smell it when the tank is near full, outside and slightly inside the car.
    I looked underneath and my passenger side of the tank is dented in on the bottom, it also looks a little damp on the bottom of the tank near the middle of the car.
    I just opened up the inspect lid from under the rear seat and there is a very strong gasoline smell. All the hoses look ok, however all around the connection into the tank area (is this simply the pump?) the paint is bubbling up/peeling right around where it goes in the tank and appears wet. I'm guessing this means that the seal needs replacing and this is likely the leak?
    I tried looking at the parts diagram/stores but cannot seem to find this gasket/o-ring. Can anyone direct me to it?
    Thanks!
    Different strokes for different folks.
  • SlamedIAm
    • May 2011
    • 318
    I believe this is what you're looking for.
    http://www.blunttech.com/ShopByVehic...-1641140@@Fuel Sender Gasket&mode=PA
    If you're an early model it might be different.
    Edit- Looks like that link might not work. It's listed as Fuel Sender Gasket on blunttech
    • Threehz
      • 1480
      Well that appears to be the right part, tomorrow I guess I'll dig in there and see what exactly isn't sealing properly. Thanks for the infos!
      • Killacortes
        • 1937
        Pelican parts.com should have what your looking for brah
        r3v does not fuck around. First you get banned, then they shoot you
        • Threehz
          • 1480
          I thought so too but upon looking on pelican I couldn't find it? Just the whole pump/sender setup
          • Threehz
            • 1480
            Ok so opened up the inspection lid and it's not actually wet around that area, just the paint is peeling, and a strong smell of gas.
            The bottom of the tank however under the car IS wet and I can smell gas down there too. I cannot see where it would be coming from but I'm assuming somewhere on top of the tank must have a hole or one of the hoses is broken in an unreachable place.
            Anywhere else I should check before dropping the tank?
            • AndrewBird
              The Mad Scientist
              • 11898
              I would try replacing that seal first anyways. Just because it is not wet up there doesn't mean it isn't leaking. The gas could have evaporated by now.
              It would suck to pull the tank if you don't have to.
              • Threehz
                • 1480
                No doubt about that, just seems weird since that area is dry but the underside is wet.
