sunroof is stuck.
  • LowR3V'in
    • 4209
    sunroof is stuck.
    The back part is sorta sagging and I think it fell off the rails because the motor definatly spins in both directions but the roof doesn't move.
    What to do?
  • EtaSport
    • 2853
    Check to make sure there are no obstructions. I had a screw stuck in my track a few weeks ago and thought the whole thing crapped out. Motor would not open it. Take the cover off and use the allen wrench in the tool box to crank it manually, just to see if you can get it to move. Dont force it though.
    Old and improved:
    • LowR3V'in
      • 4209
      I'll let you know what happends.
      • LowR3V'in
        • 4209
        Thanks for giving me that idea etasport.
        what the problem was that a screw that holds the motor to the gear was backed out ALLOT so I had to press the motor up with my fingers so it grabs the gear.
        Problem found and will be fixed!
        • EtaSport
          • 2853
          Aha.. Glad to see you figured it out. I was freaked that I wouldnt get mine closed and it would rain in it.
          Old and improved:
          • e30 gangsta
            • 3877
            if you would wanna change the whole sunroof. You would change the rails and crank and thats it?
