Will an "T" style ICV from an 89-91 325i/is work on an 87 325i that originally had the "L" style ICV?
ICV Question
You'll probably need the boot for an automatic car as well since the extra vacuum port for the brake booster on the boot is only there on automatics for later cars.Originally posted by rs4pro3Yes as long as you have the correct boot from the AFM to the throttle body for the T-ICVAdam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Later auto cars have multiple hoses and a multiport check valve. from teh throttle, boot and to the booster. THe later manual cars just have one line from the throttle to the booster with the check valve.Originally posted by Ritalin KidActually the vacuum port for from the brake booster hooks up to the throttle body not into the boot.
James
