So I know there is a million ways to do the clutch fan delete, replace with electric fan, I'm just looking for some advice so I don't order the wrong things.
91' 318is, stock fan is just under 16" but the shroud will definitely fit a 16" fan + enclosure.
This is the fan I'm looking at getting http://www.spalusa.com/store/main.as...&item=30102120
CFM is 1918, will this be at least equivalent to the stock fan?\
I live in Tucson, AZ so in summer seeing 120 degree days won't be a surprise, on top of that, the air temperature coming up off the road/pavement reaches at least 130+ degrees
I'm not looking to do this mod to see any substantial HP gain, but instead to take some weight off my engine's shoulders.
From reading about this being done I plan on going about it like this:
Remove stock Aux fan
Remove clutch fan (what do you put in place where fan clutch is?)
Attach new 16" Spal fan to stock fan shroud, pulling of course
Wire new fan up to old Aux fan fuse connection
Wire E36 M44 temp sender to radiator (not sure about this part?)
Pray shit works?
Anyhow I'd really like some advice on this because not only is the summer hot as hell here, but that means using the AC full blast as well. The last thing I want is an underpowered cooling system. Thanks!
Pray shit works?
