What else to replace when replacing Master Cylinder?
  • Stu Mc
    • 4083
    I will probably replace my MC this weekend, stock to V12 unit. I know I need two of the gaskets/grommets that go under the fluid reservoir, but are there any other parts needed?
    Any help is appreciated from those that have done the procedure.
    Thanks
  • BimmerToad
    • Sep 2004
    • 1537
    Make sure you use flared wrenches on the hard brake lines so that you don't run the risk of stripping the metal 'crush nut' things.
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      Please excuse my ignorance but what is the "v12" unit master cylinder?
      • James Crivellone
        Head Janitor
        • 6291
        From a 750iL. 25mm as opposed to the E30's 23mm
        • kowalski
          • Jan 2005
          • 1791
          what exactly is the advantage to that?
          • e30Matt
            • 5077
            Better brake pedal, more of a "squeeze" feeling than a "stand on the pedal" feeling.
            As for the master cylinder, use a flared wrench as mentioned above, and I assume you're doing a flush on the brake fluid.
            • dableds
              • Mar 2005
              • 53
              Don`t forget to change brake fluid in all system :)
              and wash the reservoir with new brake fluid
              • SchnellerVert
                • Sep 2005
                • 3948
                Stu, talk to UNHCLL, he did it and I believe he was not pleased with the setup.
                • DanGillan
                  • Mar 2004
                  • 4061
                  yea there was a issues somewhere about the 25mm master "feeling" better but performing worse. i could be wrong. check it out though
                  Dan
                  • Stu Mc
                    • 4083
                    Cool, so it looks like just the MC, gaskets and flushing the reservoir.
                    I'm replacing the master cylinder with the V12 unit because: a) my MC has 285k on it and I believe it is causing my mushy pedal. b) i have a brand new, in box V12 unit available for use at no cost. I'm using it with the stock calipers/rotors for a short while before upgrading this winter.
                    I'm not expecting a jump in braking performance, I just expect a solid pedal and an MC that will move a lot of fluid. Pedal feel is purely preference anyways, I may adjust the brake pedal if necessary.
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      E30 M3 is 23mm. Ours are even smaller.
                      • nickmp0wer
                        • 1427
                        you might want to replace the o ring that goes in between the booster and the MC or at least remember to put it back in unlike me. I definatly noticed a decrease in performance when i forgot to put it back in, but i cant say anything about with it in becasue i changed the pads and rotors and shit. Write a review after you install yours
                        • nickmp0wer
                          • 1427
                          so how did it affect the braking performance?
                          • James Crivellone
                            Head Janitor
                            • 6291
                            Really? the one that came with my car was listed as 23mm on the side and had the correct E30 325 part number
                            • Mystikal
                              • 9602
                              From what I recall the stock MC is like 19mm, hence why the 25mm model is such a drastic change (and why some believe it's not productive). If it was really just a 2mm change, people wouldn't be responding like that.
