1992 325ic - the lights glimmer or dim
    1992 e30 - The lights glimmer or dim then brighten with increased rpm. Steady at idle. What should I test or looking for to return them to steady?
    Matt
    McLean, VA
    At the least, a new brush/regulator assembly in the alternator and at the worst a new alternator. If the alternator bearing are good a brush/regulator may be all that's needed Also make sure that the engine to chassis ground is in good condition and making good contacts.
      There was quite a squawking :( so it is likely time to replace the alternator. I will inspect the bracket, nut, belt and do the whole job.
      Jlevie, thanks for the prompt assistance.
      Matt
      McLean, VA
        There's a Valeo in there now. Ever heard of a Valeo? Seems to spin OK, maybe one of the water pump, power steering pump or AC compressor are creating the squawking. Alternator belt, bracket and nuts look good too.
        Matt
        McLean, VA
          If the bearings in the alternator don't make noise when you spin the alternator pulley or otherwise feel loose, the noise will be from something else. A likely candidate would be the water pump.
            Not sure if this is what you're looking for, but I just replaced the voltage regulator in my Valeo alternator. My symptom was fluctuating lights (headlight and instrument lights) at idle that went away with revs. You sure the squawking isn't a worn belt? I'd hate to see you do a whole alternator replacement (Valeos are tricky to find) for just a voltage regulator.
