Fuel Pump or Relay problem
  • c2l0y0d2e
    • 11
    this is my first post - is there an archive where I can research problems? My wife's 325ic (purchased a few months ago for $500 - needs a new top and interior, and has the other usual neglect problems) has developed a problem where it suddenly cuts out. replaced the computer, spark is ok, I got it running once with a couple of thumps in the fuel pump area. I am open for suggestions. I am primarily a 2002 guy, but like the E30s a lot too.
  • c2l0y0d2e
    • 11
    I found the search engine. I also have replaced the fuel filter.
    • steinbachphoto
      • Aug 2007
      • 914
      If you got it to work by hitting the tank then common sense would dictate that's a fuel pump issue.
      http://www.steinbachphoto.ca
      • dogsbark26
        • Nov 2008
        • 533
        Welcome to the forum.
        Have you gotten the fuel pump issue sorted?
