Hello Everyone,
I own a ’90 turbo e30 and want to see if you guys can help me with a problem I’m having. I’ve taken it to two mechanics and they can’t seem to find a solution. Let me lay out some of the basics for you first:
--the car has 24lb injectors for the turbo
--the car (luckily) has an air/fuel ratio gauge right above the steering wheel. A proper ratio is 14.8.
--I have replaced the spark plugs with new ones.
Now for the story. I left an inside light in the car one night, and the next day my car battery was dead. After reviving the car I noticed that the car was running extremely rich when the car started. I share a theory with the previous owner that the car’s ECU was reset when the battery died (the trip computer was reset as well), but as I let the car idle the Air/Fuel will get back to 14.8 after 3-4 minutes. I then drive the car once it hits 14.8. A few things to note about waiting for 14.8:
--When I start the car, it’s almost like the battery is dead. Almost no sound is made, there’s a delay and a couple of little cranks come from the engine like it absolutely doesn’t want to move. Then after those 2 or 3 small cranks the engine bursts on and everything is golden.
--The car starts at 7.4 A/F. It jumps to ~11.8 after 30 seconds. It sits there for 3-4 minutes, and then once it hits a threshold of maybe 12.5 it jumps to 14.8.
--The car takes a good minute longer to 14.8 when it’s cold out. If I drop by a quick errand such as the cleaners, once I start the car 5 minutes after I turned it off it takes 1-2 minutes to hit 14.8.
Diagnostics on the car say it’s fine. The battery voltage is fine. I believe it has something to do with the cold start/ignition system. Does anybody have any suggestions? Much thanks in advance.
