Convert popout windows to fixed
  • Varinn
    • 780
    Has anyone done this? I know the reverse is common. My popouts are leaking like mad and I have access to a fixed rear setup for cheap ($15) with free unused and in bags OEM seals. I dont care about the actual popout feature, I rarely use it. Aside from the glass and seals itself, what else is needed?
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
  • dothadance
    • Jun 2011
    • 1121
    caulk
    • Dirtsquirt
      • Nov 2004
      • 686
      Easy swap.
      You need the external frames (trim), glass and seals. Use a plastic trim spoon to pull the seal up and over the metal lip.
      You will have 4 unused holes in your headliner after you're done, though. So just be aware of that.
      -Dan
      • Alberthype
        • May 2011
        • 135
        If you end up doing this you should document it, i'm interested in doing this cause they keep wiggling around when i'm driving and making a really annoying sound. ughghh
        • Varinn
          • 780
          Originally posted by Dirtsquirt
          Easy swap.
          -Dan
          The 4 holes from the latch mount? That can be solved, couple of little black screw caps could cover it without looking TOO ghetto
          1990 332i, 4 door
          2017 Mazda CX-5 GT
