noise from rear of car. grumbling
  • rodrigo
    • Aug 2007
    • 923
    Hi guys,
    After having the car for almost 60,000 miles (currently at 181,000) I finally have a weird noise coming from the rear end of the car.
    A: When accelerating (accelerator pedal is down) there is no noise, when completely off the accelerator pedal (coasting) there is no noise, but in the 1-2 second transition of going from throttle to no throttle, there is a howling/grumbling that comes from the rear end (trunk area, etc). To make the noise go away, I can just accelerate again or wait a few seconds.
    B:When I blip the throttle while driving there is knocking that also comes from the rear. Knocks when I hit the accelerator, and knocks when I let go.
    What the heck could these noises be coming from?
    The car has the original transmission and dif. with 181,000 miles. It is a 325i automatic (yes I would love it if it were manual but it is not, and I am not going to do a swap). Wheels are tight, nothing looks loose under the car.
    Any suggestions/hints/experiences with this?
    Thanks! :)
    I'll bet that an inspection by an experienced BMW tech will reveal likely causes for the car's symptoms.
    • immajackuup
      • Dec 2010
      • 1132
      i have that noise
      • rodrigo
        • Aug 2007
        • 923
        Originally posted by immajackuup
        i have that noise
        What is that circled in the picture...bearing on the shaft side?
        • rodrigo
          • Aug 2007
          • 923
          I agree. I do like to try asking here first as most people tend to have the same issues with the same cars. If it is something I can do myself, all the better.
          • immajackuup
            • Dec 2010
            • 1132
            jack your car up then turn the shaft back and forward,you will hear that clucking sound. think they call it back lash which you just need a adjustment.
