No power windows or headlights, no blown fuse?
  • Asbradley21
    • Jun 2008
    • 1938
    So my low beams and windows died last night while I was driving. There are no blown fuses and I've reseated all of the relays. You can hear the relay click when you pull the switch for the lights, but no lights turn on.
    The window switches do not light up, so there's no power going to the switches. What am I missing? I've been looking for a bad ground but I don't really even know where to start with that.
    S54B32 swap in progress. Status: Getting There
    Using the wiring diagrams from http://wedophones.com/BMWManualsLead.htm start tracing out the circuits to see what is going on. A DMM is the best tool, but a test will work.
    • barry
      • 1642
      Check your relays..
      • ZM Blue Devil
        • Dec 2006
        • 13836
        Do the lights on your HVAC panel light up?
        Replace headlight switch.
        Levent
        %20levent@gutenparts.com
        Ladies:
        • ezlnh8u
          • Feb 2012
          • 254
          remove fuse # 10, and se if that fixes it.
