Cruise control Actuator
  • barry
    • 1642
    Hi Guy's
    Couple questions, installed a new CT cable does it have to be adjusted in order for the actuator to work? Also what fuse number is designated for this system? Is there a relay? Can't seem to get it to work. Any in formation would be appreciated.
    Thanks
    Barry
  • vpilarrt
    • Jun 2006
    • 2096
    You talking about the Bowden (push-pull) cable? That doesn't have to be adjusted to function although you may not be able to get full throttle movement until you do adjust it. But it sounds like you need to the system working first - so: Fuse #6 supplies power (Fuse #10 also if you have an automatic). Remember you have to push the brake pedal and clutch pedal in at east once before the system will start working. It also has to be getting a speed signal from the main ECM.
    • barry
      • 1642
      Hey thanks Vpilarrt, will try again in the morning
      Barry
      • gearheadE30
        • Jun 2007
        • 3734
        If you end up needing any cruise parts, I probably have what you need.
        Project M42 Turbo
        • barry
          • 1642
          Thanks Gearhead
          Barry
