Anyone has tips for successfully draining coolant without making a mess? The anal landlord don't want me to dirty his concrete.
Draining engine coolant
You can easily drain the radiator w/o making a mess. The block, not so much. You will make a mess when you drain the block. If you can't drain it on the driveway, take the car somewhere that you can drain the block.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
I take a 20oz bottle and cut the large end at an angle. Using both hands, you can unscrew the bolt quickly place the cut end of the 20oz bottle over the block/hole. Then you can aim the flow into bucket. Don't try this while the coolant is hot, you will get burned.Comment
