New Question:
The clutch on his eta is bad. Is there anyway that I can install a clutch and flywheel from an I car, or will that not work?
Also... one of my other friends has a 2 manual transmissions. the good transmission does not fit the driveshaft and but the bad one does. He mentioned swapping the output flanges. Is that possible? Seems pricy to me.
I'm contemplating my options since my motor blew and now is the perfect time to 5-speed swap.
Old / Answered Question:
Code:
I have a friend that is selling a 5 speed transmission off of an 1984 325e. I'd be going from an autotragic to a manual, so I understand I'd need the full set up, like the driveline, clutch, flywheel, etc... Would the transmission from the 325e work with my 1988 325iC or are the gears different on the e - i models? Thanks, [I]Spencer[/I]
