Is my evaporator leaking?
  • gkurey
    • 882
    Hey guys...I'm replacing all my o-rings and a few AC system components for a R-134 conversion. I decided to pull out the evaporator to have a look at it and just check it over. I noticed some green stuff and general nastiness on the copper lines going into the core. I feel like that's probably indicative of a leak, but I want to be sure it isn't something else/normal. What do you guys think?
    Thanks for looking!
    I don't know it that is a leak or not. Clean the crud off and pressure test the evaporator.
    • gkurey
      • 882
      Can most AC shops pressure test components?
      • Chuck C
        • 104
        That looks like AC leak-detector dye residue--whick means a leak.
        • gkurey
          • 882
          ^^^ That's what I was thinking...probably not even worth the money to check. A friend of mine shot me a link from somewhere stating that compound material evaporators (like mine, aluminum and copper) commonly leak because each material has a different expansion/contraction rate and range so leaks form over time from cyclic wear. Makes sense...especially on a 23 y/o car.
          • gkurey
            • 882
            This replacement looks to be all aluminum...I may give it a try...I mean for 70 bucks?! Can't hurt. Hopefully it isn't of crappy construction though, haha!
