See update list below with questions
Putting down a shopping list for some well due maintenance: timing belt (and waterpump while at it) and ignition. I already have air-oil-fuel filter. Oil change will be done after the above is done. Anything else I should replace while the rad is out and the front of the engine is off?
Anything I am missing or I can go without?
Updated list:
Gasket for Thermostat Housing
Crankshaft Seal Front 48 X 65 X 10
Rubber Seal for Timing Belt Cover
Gasket for Front Engine Cover
Seal for Camshaft and Intermediate Shaft 38 X 50 X 7 mm (2 Per Car)
Cam Flange O-Ring (RED)
Water Pump Gasket
Thermostat O-Ring 60 X 3.5
Water Pump (Single Outlet) NOTE: Also use- (1) 11 51 1 722 677 gasket
Belt Alternator 10 X 965
Tensioner Spring for Timing Belt Adjusting Pulley Assembly
Copper Washer 12 X 17 X 1.5 mm Oil Pan Drain Plug
Ignition Rotor Bolt-On Type
Distributor Cap
Timing Belt Kit Contains: (1) Timing Belt (1) Adjusting Pulley (1) Mileage Sticker
Thermostat 80 deg. C
Car has been in storage for the winter, any value in starting her up before doing all the maintenance work?
Updated list:
Water Pump Gasket
Distributor Cap
