Cruise control inoperative
  • mcruz121
    • 288
    My Cruise control has never worked since I got the car. PO did put in an instrument cluster.
    What should I look for? Do I need to pull out the cluster?
    Check to see if two wires are connected to the green plug. One of those is the speed signal from the differential and the other feeds that signal to the OBC & cruise control.
    • dogsbark26
      • Nov 2008
      • 533
      Yes. Remove cluster. Remove all six screws (four along bottom edge and two on "ears" at top) then tilt out from top first. May find it easiest to remove steering wheel first (but not necessary).
      Green plug is found on back of speedometer housing.
      Two wires jlevie? Mine has only one wire to green connector. It is for cruise control. Goes in any of the three similarly shaped sockets on the green plug.
      • Zzyzx85
        • May 2012
        • 131
        Yup, I have two wires as well. Does one of those wires have anything to do with the ABS light or did i not connect something?
        - '89 325i 4-door, Alpinweiss, 5-spd swap (and lots of maintenance) in progress
        - '03 M3, Imolarot, 6 speed
          The speed signal wires have nothing to do with ABS.
          • PeaveyBassist
            • Sep 2004
            • 3511
            Here is a thread with my findings a while back. Hopefully this helps a little.
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
