84 cluster issue
  • gemini325es
    • Dec 2008
    • 4
    84 cluster issue
    Ok so I deleted my si board and did the jumper wire and my gauges work. Cleaned my grounds and I'm still driving down the road and my mph and tach are still intermittently dying. If I give the dash a slap they come back. So I need some advice to where I can start checking for connections when I pull the cluster tonight to sort this out. Thanks again.
  • Jaxx_
    • Dec 2009
    • 1880
    C2 #16 is the common ground. It is a brown wire. It grounds at G200. They don't have a common power source so I don't think that that would be the culprit.
    • gemini325es
      • Dec 2008
      • 4
      I don't have a Bentley yet too look up the diagram for that circuit. Could u be more specific. Thanks.
      • Jaxx_
        • Dec 2009
        • 1880
        I told you everything you need to know.
        check the two connectors at the back of the instrument cluster. one of them will have a brown wire on pin 16. that should be grounded. check continuity to the body.
        • gemini325es
          • Dec 2008
          • 4
          Ok thanks.
