window stuck down. helps!
  • Il Duce
    Non-Mod M42 Modder
    • 5042
    i really dont like starting threads, but my car is a 1990 and it doesnt have the normal manual crank just in case my window motor goes out. so my question to you guys is: how the hell do i get this window up?
    TIA
  • DaN
    • 1265
    Is the window motor bad? If so you might need to disconnect the motor from the regulator and lift the window by hand.
    If the motor is still good then put power and ground to the connector.
    • jajou318
      • Jan 2005
      • 1023
      Disconnect the motor. Take the wires and hook it up to a battery from a drill and pos or neg doesn't matter. If it goes down with pos touching a certain wire than switch the wires touching the battery.
      Good luck,
      Tony
      • nefarious7907
        • Jan 2005
        • 1170
        Good luck,
        Tony
        have an extra fuse on hand. my 2c
        http://www.cardomain.com/ride/657387
