vert leak only when moving
  • hendrixvodu
    • Jan 2007
    • 2514
    my car can sit all day long and not leak but as soon as i drive it and turn water leaks from the normal front a pillar spot ...is the water not being channeled out correctly ?
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
  • dnguyen1963
    • Nov 2011
    • 2651
    You need to put silicone under the rubber seal starting from the driver door and go all the way to the other side. Remember to open the roof partly so you can get deep inside the seal.
    • hendrixvodu
      • Jan 2007
      • 2514
      GREAT! i put a new seal on and did not silicone it will give that a shot tonight thanks!
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
