Electrical Issue Help
  • Aptyp
    • 6584
    What would cause the head unit and check panel and lights to remain on AFTER the key is out of the ignition.
    Ignition switch was taken down and replaced. Testing through the switch, same problem exists.
  • DaveSmed
    • Apr 2007
    • 1407
    Easiest way to narrow that down is pull fuses (except for the headunit and check control) until they shut off.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
      That suggests that something is providing power to the Acc circuit other than the ignition switch.
      • Aptyp
        • 6584
        done that, been tracing wires, but nothing it out of ordinary
        • StereoInstaller1
          GAS
          • 22679
          I want to see a pic/diagram/detail of the deck wiring, even if it is stock.
          Closing SOON!
          Thanks for 10 years of fun!
          • Aptyp
            • 6584
            it is stock, but how would you explain check panel and the lights?
            • DaveSmed
              • Apr 2007
              • 1407
              Ok, just for a laugh, turn your hazard lights on. See if the radio turns off.
              -Dave
              • StereoInstaller1
                GAS
                • 22679
                Some eveil (insert "Thriller" laugh here) hackery has happened behind many a stock deck.
                AFAIK, (too little time to look at diagram right now) the check panel is powered by the same branch of the ignition circuit as the deck. Some retarded PO hackery would cause that...possibly.
                Luke
                Closing SOON!
                • Aptyp
                  • 6584
                  I was the previous owner :-(... Actually I've owned the car twice and it was under Korman care for 20 years before that. I think it's the lack of hackery...
                  Anyway, traced everything to the light switch. I'll replace it with another one just for the hell of it, so I can rule it out.
