16" Reversible Electric Fan 16 inch Pro Series Extreme
  • immajackuup
    • Dec 2010
    • 1132
    How do I make this fan as a pusher instead of puller??
    Do I flip the blade or change pos to neg and neg to pos wires?
  • HarryPotter
    • Jan 2010
    • 3642
    I don't believe you can just flip the wires. Just flip the fan around.
    John F. Kennedy
    • MaksV
      • 1042
      You can flip the polarity. Its just a DC motor. run current one way and you get it spinning in one direction, run current the other way it spins in opposite direction.
      CHEAP REBUILT INJECTORS
      Need Quality Brakes? BimmerBrakes has it!
      For anything Else go with BluntTech!
      • HarryPotter
        • Jan 2010
        • 3642
        Fuckin DC power. AC's a whole different ball game.
        John F. Kennedy
        • immajackuup
          • Dec 2010
          • 1132
          this the fan i got
          http://www.ebay.com/itm/310395313361...84.m1497.l2649
          • HarryPotter
            • Jan 2010
            • 3642
            maks right.
            John F. Kennedy
            • MaksV
              • 1042
              I send you details about your pm. If you still dont believe me put it on the terminals of the battery. red to pos and black to neg, then swap it, and watch the blad spin in different directions.
              • HarryPotter
                • Jan 2010
                • 3642
                Dude it will work I've done it with the cars blower motor. Nothing will happen besides the fan spinning one or the other which ways. I fergert when I first posted. 100% sure.
                John F. Kennedy
                • immajackuup
                  • Dec 2010
                  • 1132
                  thx yall
                  • FLG
                    • Sep 2011
                    • 3165
                    They're correct, but you might also want to flip the blades as well as depending on the blade design you might loose CFM by just reversing polarity.
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • immajackuup
                      • Dec 2010
                      • 1132
                      you are correct sir on the blade thing.
