If I leave the battery connected there is a slow drain.
If I turn the key to the start position I can hear the starter solenoid click but engine doesn't turn. But, then the car loses power (i.e. dome light, trunk light are out but the battery still shows 12V at the terminals (on the wire side of the terminal, so it's not just a bad connection)).
If I disconnect the batter then after a random amount of time the car gets power again (sometimes a few minutes sometimes a few hours). If I don't disconnect the battery it slow drains.
So far I've been so stupid that when the car does have power I forget to check the engine diagnostic codes (or the BOSCH injector cpu codes). Of, course then I kill it by trying to start it and when there isn't power I can't check these things.
I've tried disconnecting the fuel pump and the ignition coil to see if it was a short in either of these components. But, the behavior is the same.
The car had this exact same behavior 2 months ago and I towed it to the neighborhood shop and they told me I installed my aftermarket radio wrong but didn't tell me what they did to fix it. Whatever they did it ran for a month then had the same symptoms. However, I used very unique shrink wrap on all of the radio wires and they definitely didn't repair any of my wiring (moreover I triple checked everything and read several thread discussing aftermarket radio installation and the car ran fine for months afterwards).
Could it be that they just banged on the starter and so it worked for a month? But, it this is so why would the starter kill the vehicles power system? I really don't want to replace the starter since I've read that it's a huge PITA.
I haven't banged on the starter myself nor have I tried to push start it (there isn't really a good place for me to do this where I live).
Does anyone have advise on tracking this down? Could it be bad engine or chassis grounds (and how would I know if they are bad)? If it's a short how do I problem solve it?
Any help is massively appreciated.
